what else can u do with vagcom apart from check for faults
Posted: Fri Mar 20, 2009 7:12 am
by rtd
as above really - are there any other uses for vagcom?
RE: what else can u do with vagcom apart from check for faul
Posted: Fri Mar 20, 2009 9:22 am
by PetrolDave
1) Recode the way many units behave e.g. door locking over 5mph, drivers door only on first press, window closing from remote, etc.
2) Change the coding of units when you retrofit e.g. cruise control, full DIS, sat nav, etc.
3) Reset the service warning indication (fixed and AVS).
You need to look at both the Ross-Tech website (for vehicle procedures) at
http://www.ross-tech.com and the Ross-Tech wiki at
http://wiki.ross-tech.com. The OpenOBD website is good too at
http://de.openobd.org
Posted: Fri Mar 20, 2009 10:38 am
by Blue_Thunder
Logging to measure various aspects of engine performance, ie: boost spec/actual, MAF readings, misfire detection, long term fuel trims, etc.
