first time using vagcom
Posted: Thu Mar 19, 2009 7:16 pm
ok guys i did a normal scan (if thats what you call it) and this is what came up. does this mean these are the only faults vagcom found or are there other scans i can do to look for faults elsewhere? not that i want to find any other faults
Thursday,19,March,2009,17:41:33:14480
VCDS Version: Release 805.3
Data version: 20090213
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: WUAZZZ8DZ1N904257
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 63351
WUAZZZ8DZ1N904257 AUZ7Z0Y1767343
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 00720
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00061
Shop #: WSC 63351
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 F
Component: Airbag Front+Kopf 2001
Coding: 01306
Shop #: WSC 02314
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981
Component: B5-KOMBIINSTR. VDO D13
Coding: 00464
Shop #: WSC 00720
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15210
Shop #: WSC 63351
1 Fault Found:
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
End ---------------------------------------------------------------------
Coding: 10711
Shop #: WSC 63351
Coding: 04395
Shop #: WSC 00720
Coding: 00061
Shop #: WSC 63351
1 Fault Found:
Coding: 01306
Shop #: WSC 02314
Coding: 00464
Shop #: WSC 00720
Coding: 15210
Shop #: WSC 63351
1 Fault Found:
35-00 - -
Coding: 00102
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
