Central locking coding
Post by Shoppinit » Tue Mar 10, 2009 10:55 am
Hi, does anyone know if it's possible change the coding to have the doors lock above a certain speed (say 5mph) like in the USA? I haven't found anything looking around.
Edit: I foudn the codes for the S4, would be it the same for RS6? Could just try I suppose :)
GardinerG
RE: Central locking coding
Post by GardinerG » Tue Mar 10, 2009 11:34 am
http://www.rs246.com/index.php?name=PNp ... c&start=15
P.s. sometimes the older '6s can stop autolocking even though they have the right coding - make sure you make a note of the current coding before changing it. ;-)
(It requires a new central locking module to fix at around £200.)
HTH
Grant
Post by Shoppinit » Tue Mar 10, 2009 6:13 pm
Brilliant. Thanks, Grant. Not sure how I missed that.
I'll try coding it with the VAGCOM and if it doesn't work, I'll leave it be.
Post by Shoppinit » Tue Mar 10, 2009 6:14 pm
PS. Did you fix it on yours? Do you have the part number by any chance?
GardinerG
Post by GardinerG » Tue Mar 10, 2009 8:41 pm
No and nope. Using VCDS opening and closing the module gets it working again and I don't have to do it that often. £200 goes too far elsewhere. ;-) Another example of Audi needing to do a recall.
Grizz, can you get the central locking module for a good price?
G
Return to “DTC / VCDS”
