Need help with RNS-E and Instrument Cluster codes
Posted: Wed Dec 24, 2008 5:32 am
OK, I got the yellow symbol on the cluster for the oil sensor (oil level/temp switch).
Switch was replaced but the sensor light is still on. Second, I'm planning to upgrade my transmission (the weakest link other than the DRC) but lately I've noticed slight slippage during hard acceleration. Third, I installed a RNS-E which works great, sounds great! But since installation, I always get 2 codes while scanning; 00625 and 02005. I did a scan this morning and here's the readout;
Thursday,18,December,2008,09:38:43:62497
VCDS Version: Release 805.1
Data version: 20081017
Chassis Type: 4B - Audi A6 C5
Scan: 01 02 03 06 08 15 16 17 18 34 35 36 37 45 55 56 57 65 67 75
76 77
VIN: WUAPV64BX3N904642
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558 D
Component: 4.2l V8/5VT G 0003
Coding: 0006752
Shop #: WSC 02559 776 31376
1 Fault Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 004 - No Signal/Communication
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FL
Component: AG5 01L 4.2l5VT USA 0305
Coding: 0000002
Shop #: WSC 00000 785 00200
No fault code found.
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
1 Fault Found:
01119 - Gear Recognition Signal
35-10 - - - Intermittent
Address 06: Seat Mem. Pass Labels: None
Part No: 4B0 959 760 C
Component: Sitzmemory R1 BF 0205
Coding: 00003
Shop #: WSC 00000
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 4B0 820 043 AR
Component: A6-Klimavollautomat 0208
Coding: 00010
Shop #: WSC 00000
Address 15: Airbags Labels: None
Part No: 4B0 959 655 Q
Component: Airbag 8.4EP 2001
Coding: 0000607
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 983 D
Component: KOMBI+WEGFAHRS. VDO D13
Coding: 03284
Shop #: WSC 02120
WUAPV64BX3N904642 AUZ7Z0C2422946
3 Faults Found:
01302 - Control Module for Telematic (J499)
49-00 - No Communications
00562 - Sensor for Oil Level/Temperature (G266)
30-00 - Open or Short to Plus
27-10 - Implausible Signal - Intermittent
Address 35: Centr. Locks Labels: 4B0-962-258.lbl
Part No: 4B0 962 258 M
Component: Central Lock/Alarm D38
Coding: 15981
Shop #: WSC 02120
Address 36: Seat Mem. Drvr Labels: None
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
Shop #: WSC 00000
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US3 H74 0200
Revision: 03S Serial number: AUZBZ7G2403985
Coding: 0519611
Shop #: WSC 06325 000 00000
2 Faults Found:
00625 - Vehicle Speed Signal
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.29
Time: 16:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2911
Clock: 16:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.14
Time: 13:13:41
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00050
Shop #: WSC 00000
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0519611
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.29
Time: 16:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2911
Clock: 16:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.14
Time: 13:13:41
Address 75: Telematics Labels: None
Part No SW: 8E0 035 616 A HW: 8E0 035 616 A
Component: Telematik USA1
Coding: 0002003
Address 76: Park Assist Labels: 8Z0-919-283.lbl
Part No: 8Z0 919 283
Component: Parkingsyst. A6 RDW D08
Coding: 01116
Shop #: WSC 00000
End ---------------------------------------------------------------------
Thanks in advance.
76 77
Coding: 0006752
1 Fault Found:
Coding: 0000002
Coding: 06697
Shop #: WSC 00000
1 Fault Found:
Coding: 00003
Shop #: WSC 00000
Coding: 00010
Shop #: WSC 00000
Coding: 0000607
Coding: 03284
Shop #: WSC 02120
3 Faults Found:
Coding: 15981
Shop #: WSC 02120
Coding: 00001
Shop #: WSC 00000
Coding: 0519611
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.29
Time: 16:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2911
Clock: 16:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.14
Time: 13:13:41
Coding: 00050
Shop #: WSC 00000
Coding: 0519611
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.29
Time: 16:47:09
Freeze Frame:
Mileage: 655350 km
Count: 2911
Clock: 16:47
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 68
Time Indication: 0
Date: 2008.11.14
Time: 13:13:41
Coding: 0002003
Coding: 01116
Shop #: WSC 00000
Thanks in advance.
