How do you check mafs
Posted: Sat Dec 06, 2008 5:41 pm
by lengster1
Vagcom the car fairly often and suprised ive never lost one,do you have to do a power run and use the results to check the maf?
RE: How do you check mafs
Posted: Sat Dec 06, 2008 8:39 pm
by frazered
yup that is what i have done - 3rd gear log from 2k to limiter
Posted: Sat Dec 06, 2008 11:08 pm
by tartan_rob
Unplug it.; If the cars runs same or better, it is stuffed.
Posted: Sun Dec 07, 2008 1:45 am
by jimbo1234567
you can check maf on vag as long as the car is fairly std. do it then post your logs. i think a std rs4 maxxes out the maf at 330 g/s ish, so just see what it does . :beerchug:
Posted: Sun Dec 07, 2008 6:11 pm
by lengster1
Thanks fellas, I will try this out when i have her back in action,im pretty sure all is ok as its always performed well,but after replacing the pre cat lambdas thought it a good idea to check
Posted: Sun Dec 07, 2008 10:40 pm
by tartan_rob
Some of the MAF's are crap. It is worthwhile checking periodically. Audi do exchange units quit cheap.
