Evap Emission Control Sys: Incorrect Flow ????
Posted: Mon Sep 08, 2008 10:46 pm
Just scanned my car and got this DTC ....
1 DTCs Found:
16825 - Evap Emission Control Sys: Incorrect Flow
35-10 - - - Intermittent
Any ideas? RossTech WiKi says;
Possible Causes
Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) faulty/jammed
Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115) faulty/jammed
Evaporative Emission (EVAP) Canister Sealing faulty
Pipes between Tank Breathing and Throttle Body leaky/blocked
Possible Solutions
Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80)
Perform Output Test
Check Evaporative Emission (EVAP) Canister Purge Solenoid Valve (N115)
Perform Basic Setting
Check Pipes between Tank Breathing and Throttle Body
Where is the EVAP canister?
1 DTCs Found:
Possible Causes
Possible Solutions
Perform Output Test
