My Rs4
Posted: Wed Aug 27, 2008 3:25 pm
Friday,22,August,2008,14:14:36:55700
VCDS Version: Release 805.0
Data version: 20080730
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUAZZZ8E87N902946 Mileage: 31240km/19411miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H13--- Serial number: XXXXXXXXXXXXXX
Coding: 01040003180F0160
Shop #: WSC 00155 264 91102
10 Faults Found:
012312 - Valve for Exhaust Flap 1 (N321): Short to Ground
P3018 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 12.192 V
001112 - Evap System Purge Control Valve (N80): Short to Ground
P0458 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
008201 - Intake Manifold Flap; Bank 1: Short to Ground
P2009 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
004199 - Intake Air Switch-Over Valve (N335): Short to Ground
P1067 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005173 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005153 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
005494 - Right Engine Mount Solenoid Valve (N145): Short to Ground
P1576 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 217 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
008853 - Fuel Pressure Regulator Valve (N276): Short to Ground
P2295 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 29257 km
Time Indication: 0
Freeze Frame:
RPM: 230 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Short to Ground
P0031 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit: Short to Ground
P0037 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 00031
Shop #: WSC 06335
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
4 Faults Found:
005490 - Left Engine Mount Solenoid Valve (N144): Short to Ground
P1572 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 234 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
004764 - Fuel Pressure Regulator Valve; Bank 2 (N276): Short to Ground
P129C - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29325 km
Time Indication: 0
Freeze Frame:
RPM: 231 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit: Short to Ground
P0051 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
000087 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit: Short to Ground
P0057 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 G HW: 8E0 959 655 G
Component: Airbag 9.41 H12 3730
Revision: 91H12373 Serial number: 0036M0G3BCL8
Coding: 0430612
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0301
Coding: 06021
Shop #: WSC 06335
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 931 G HW: 8E0 920 931 G
Component: KOMBI+WFS 4 H14 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023111
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 K HW: 8E0 035 192 K
Component: RNS-E HIGH EU H72 0650
Revision: 01S Serial number: AUZBZ7F1181507
Coding: 0309713
Shop #: WSC 02195 785 00200
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CH
Component: Komfortgerát T3B 4135
Coding: 06762
Shop #: WSC 06335
Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
2 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000005
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309713
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0022523
Shop #: WSC 02197 785 00200
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 E HW: 8E0 919 283 E
Component: Parkhilfe 8-Kan H06 0010
Revision: 00H06000 Serial number: 00067802120624
Coding: 0000104
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 Q HW: 8P0 862 335 K
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005147235
Coding: 0011544
Shop #: WSC 00000 000 00000
End ---------------------------------------------------------------------
69 75 76 77
10 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 238 /min
Load: 83.5 %
Speed: 0.0 km/h
Temperature: 72.0°C
Temperature: 62.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 217 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Mileage: 29257 km
Time Indication: 0
Freeze Frame:
RPM: 230 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 785 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Coding: 0004533
Coding: 00000
Shop #: WSC 00000
Coding: 00031
Shop #: WSC 06335
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Mileage: 27555 km
Time Indication: 0
Freeze Frame:
RPM: 234 /min
Load: 80.0 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29325 km
Time Indication: 0
Freeze Frame:
RPM: 231 /min
Load: 83.9 %
Speed: 0.0 km/h
Temperature: 73.0°C
Temperature: 63.0°C
Voltage: 11.049 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 29326 km
Time Indication: 0
Freeze Frame:
RPM: 783 /min
Load: 29.0 %
Speed: 6.0 km/h
Temperature: 80.0°C
Temperature: 58.0°C
Voltage: 13.843 V
Coding: 0430612
Coding: 06021
Shop #: WSC 06335
Coding: 0023111
Coding: 0309713
Coding: 06762
Shop #: WSC 06335
Part No: 8E1959801G
Part No: 8E1959802G
Part No: 8E0959801E
Part No: 8E0959802E
2 Faults Found:
35-00 - -
35-00 - -
Coding: 0000005
Coding: 0309713
Coding: 0022523
Coding: 0000104
Coding: 0011544
