Air Flow Flap Positioning Motor
Philws4
Post by Philws4 » Mon Aug 18, 2008 9:47 pm
Did a scan today and got this strange code come up ( within HVAC ), any ideas where to start looking?
http://wiki.ross-tech.com/index.php/01274
B5 S4
PetrolDave
RE: Air Flow Flap Positioning Motor
Post by PetrolDave » Tue Aug 19, 2008 11:12 am
IIRC the motor is on the LHS of the heater assembly, beside the glove box.
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Tue Aug 19, 2008 7:35 pm
Some of these motors are a reall PITA to get to and remove
Hope thats one of the easy ones.
Best thing to do is remove the glovebox, go to output tests on VAG-COM, and see which motor moves when V71 is actuated
Virdee Autos ~ 07950-526592
Philws4
Post by Philws4 » Sat Aug 23, 2008 9:33 am
Thanks guys for your coments.
What will be the result of this motor not working, because as yet i have not noticed any difference in the way the HVAC system works :?
B5 S4
PetrolDave
Post by PetrolDave » Sat Aug 23, 2008 11:02 am
Either the hot/cold air mixing or air distribution won't work properly - depending on what the flap the motor controls is supposed to do.
Philws4
Post by Philws4 » Sat Aug 23, 2008 11:40 am
Ah ok thanks Dave, i will look into this over the weekend.
B5 S4
Return to “DTC / VCDS”
