EGT codes on my 2001 RS4
ronan
Post by ronan » Tue Jun 03, 2008 12:20 pm
I have the following codes on my 18,000 mile 2001 RS4, I already replaced the MAF a few days ago and i have a new pair of S3 DV's on the way
17867 - Exhaust Gas Temp Sensor 2 (G236): Implausible Signal
P1459 - 35-10 - - - Intermittent
17869 - Exhaust Gas Temp Regulation for Bank 1: Implausible Signal
P1461 - 35-10 - - - Intermittent
I understand from searching that the 17867 code is the left side EGT sensor and i will have to replace this but what is the other code 17869? is that a faulty part or is it related to the same EGT sensor
Virdee Autos
Trader (Expired)
RE: EGT codes on my 2001 RS4
Post by Virdee Autos » Tue Jun 03, 2008 9:12 pm
I would say both codes are related to that EGT sensor
Virdee Autos ~ 07950-526592
yorkie
Post by yorkie » Sat Jun 07, 2008 6:03 pm
I think that is both sensors.
If your maf was shot that can kill the egts but try clearing the codes and see if they come back - you might be lucky!
Return to “DTC / VCDS”
