ABS error code
Posted: Thu May 29, 2008 11:32 pm
by TopBear
Anyone seen this before?
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 02325
1 Fault Found:
18265 - Load Signal: Error Message from ECU
P1857 - 35-10 - - - Intermittent
RE: ABS error code
Posted: Fri May 30, 2008 2:40 pm
by Sebastian
Sure...
http://wiki.ross-tech.com/index.php/18265/P1857/006231
...any codes stored in your ECU? Might be MAF related...
Re: RE: ABS error code
Posted: Fri May 30, 2008 2:55 pm
by TopBear
How do I access codes stored in the ECU? I thought that exactly what these DTC codes that VAG-COM get for you
Just fitted a new MAF a couple of weeks ago.
RE: Re: RE: ABS error code
Posted: Fri May 30, 2008 8:58 pm
by Virdee Autos
Just go into Engine (01) and just check for any fault codes. Present and stored will both be shown
Posted: Sun Jun 01, 2008 9:36 pm
by Sebastian
Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Posted: Mon Jun 02, 2008 10:04 pm
by Contigo
Had this on mine
Controller: 8D0 907 389 E
Coding: 04395
Shop #: WSC 02325
No fault code found.
But then it said no fault found.
Re: RE: Re: RE: ABS error code
Posted: Mon Jun 02, 2008 10:17 pm
by TopBear
Sebastian wrote:Hmm... did you clear codes after you fitted the new MAF? You may wanna try that and see if the code comes back.
Yep, cleared all codes from the Engine controller post MAF fitment.
Done another full scan tonight after running it for a few hundred miles, and its not re-occured.
