Page 1 of 2
cant reset the brake warning light
Posted: Mon Jan 28, 2008 12:30 pm
by musty1
as the title says I had a dodgy speed sensor and chaged that then it come up with brake test activated and I done the test, after the test the ESP and ABS light went off put vagcom back on no fault codes and I still cleared it but the big red warning sign still does not go out I toped up brake fluid just in case still no joy can anyone help??
RE: cant reset the brake warning light
Posted: Mon Jan 28, 2008 2:34 pm
by PetrolDave
Do the brake lights turn on when you press the pedal? Both bulbs blowing can cause the ABS failure to show.
Try checking the fault codes again - it's very unusual to have a warning and no codes.
Posted: Mon Jan 28, 2008 2:43 pm
by musty1
both light's work there is amber warning signal for the bulbs this one is the big red warning signal yeah it is very unusual for no codes I'll have a look tonight maybe do a auto scan aswell see what it comes up with cheers
Posted: Tue Jan 29, 2008 1:48 pm
by tartan_rob
Yep, VAG-COM would hopefully come up with something. Failing that check the wear sensor wiring with a Multimeter. I have blanked mine off in the RS4 as the sensors do not come with the aftermarket pads. From time to time I get a sensor fault on the dash (similiar symbol) and nothing comes up in VAG COM to tell me.
R
Posted: Tue Jan 29, 2008 2:39 pm
by musty1
cheers rob will do
Posted: Thu Feb 14, 2008 9:25 am
by musty1
still no joy checked with vag com again no falut codes but the symbol comes up with three chimes all the conectors are conected
Posted: Thu Feb 14, 2008 10:39 am
by flashyg
Sounds like a voltage issue to the abs module or pressure valve in the system.
Have you checked the abs section in vag?
G
Posted: Thu Feb 14, 2008 10:44 am
by musty1
I'm sure it said 11v on vag com and the range is 9 to 17, pressure vale how do I check that?
Posted: Thu Feb 14, 2008 11:31 am
by GrahamS4
Brake pedal switch? Think it's a common VAG failure.
Posted: Thu Feb 14, 2008 11:40 am
by musty1
on vag com in the measuring blocks it says bleed in the brake switch bit but no fault codes also the rear lights wouldn't work no ? mine do
Posted: Thu Feb 14, 2008 12:56 pm
by PetrolDave
Is the brake switch a dual circuit one? One for the ABS and one for the brake lights...
Posted: Thu Feb 14, 2008 12:58 pm
by musty1
ok i will have a look into that the fault code did come up with switch but once i cleared it did not come back but my abs light is not on and the esp light is not on just the big warning on the dis
Posted: Sat May 31, 2008 8:41 pm
by Contigo
I have this on mine and thought I could remove the coding but I see it's for MY99 motors and not a 2001. So I have to check the wires.
Checked them and they have been bodged up by someone already. Any ideas?
Phil
Posted: Mon Jun 02, 2008 9:21 pm
by neckarsulm
faults displayed on the DIS don't creates logs in the fault memory e.g. if you have low brake fluid (you dont), this wont cause a fault vag com can read.
Have a look in the manual and double check what it could mean, if it's just brake fluid you could have a problem with the brake fluid level sensor or its wiring or possibly even the cluster. Apparently BBA Reman say this isn't unusual.
What I have seen on many later cars (inc my RS4 when it was left unusued for 3 weeks) is low voltage on cranking the engine causing the DIS to display a fault relating to the brake system which clears after a few secs of the engine running - if yours stays on while driving etc it wont be this to blame.
Good luck.
Posted: Mon Jun 02, 2008 9:59 pm
by Contigo
Nah it comes on immediatley and never goes off. When I had the pads done last week the tech said that someone had previously taped up the sensor wires so I reckon the fault likes somewhere else in the loom.
Gonna be a pig to solve as it could be either side of the fronts.
