ABS pump
Posted: Thu Jan 24, 2008 4:57 pm
Help needed please!!
I have a 97 A3 t sport and i couldnt re-set the abs light. The fault code said abs pump outside specified range. I swapped the abs pump for one from a 1.8 mk golf gti as I was told that they are interchangable. I can now re-set the abs light but it comes back on when I start driving. I still have the same fault code and now it also says that the ecu cant/wont communicate with the abs pump!!!
The part numbers are 1JO 614 117 and 1JO 614 217. Does anyone know if I can get the ecu to recognise the new pump and fix the problem?? Thanks Mike
