How to calibrate MPG display after bigger injectors?
Posted: Sat Nov 03, 2007 7:58 pm
by CliveH
This question remains unresolved from a previous thread (which should probably have been moved to the VAG-COM section)
http://www.rs246.com/index.php?name=PNp ... ic&t=65560
viperbl and I have MPG differences (actual vs DIS) which, if we made adjustments using the adaptation function (channel 3), would go off the end of the scale (permitted range 85 to 115). Hence this doesn't work for such large discrepancies (well mine is still about 5% out after entering the lowest value of 85).
Oddly enough, we are at opposite ends of the scale after fitting bigger injectors :shock:
There are posts in the other thread which suggest that the adaptation is just for minor calibration, whereas there is a more fundamental setting to change, which takes account of the larger injectors.
It seems that this may be one for Uwe or Sebastian, although it is rumoured that Mihnea may also hold the key... :sekret:
RE: How to calibrate MPG display after bigger injectors?
Posted: Sat Nov 03, 2007 10:48 pm
by S2tuner
Clive, give us a shout and next time you see me or Doug you'll get an updated file. The MPG is adjusted on all our files but sometimes it's still off... :(
Posted: Sun Nov 04, 2007 12:08 am
by Sebastian
Agreed, like S2tuner said in terms of mods like yours the best option is to talk to your tuner. The instrument cluster just deals with what the ECU tells it and that should be somehow within a reasonable range, otherwise an adjustment is not possible.
Posted: Sun Nov 04, 2007 12:51 am
by CliveH
Thanks guys :thumbs:
Be seeing you soon Mihnea... :wink:
Posted: Mon Nov 05, 2007 2:31 pm
by viperbl
Good man Mihnea :)
I put mine to the max the adaptive channel well go and got to within just under 3MPG difference ... close, but no cigar
Re: RE: How to calibrate MPG display after bigger injectors?
Posted: Thu Jan 10, 2008 9:11 am
by Chubby
viperbl wrote:I put mine to the max the adaptive channel well go and got to within just under 3MPG difference
Ditto ..
Its a pain but it's good to find out it can be resolved...
R.
