OBD II Connectors
Posted: Tue Sep 11, 2007 10:58 pm
by rikrose
So, we all know that VAG-COM is the one to use, however, I don't have a laptop. I do, however, have a Nokia N800, and I a contempalting trying/extending CarMan. Question is, does any ODB-II unit get access to everything useful on a facelift B5 S4?
By useful I mean data I can read - I'm not interested in setting anything....
I'm currently considering the ODBKey Bluetooth for the reading - anyone heard any scare stories about it? Anyone know any better Bluetooth ODB devices to use, that don't cost a small fortune?
RE: OBD II Connectors
Posted: Mon Sep 17, 2007 12:42 am
by Sebastian
UK model? What model year?
EOBD (the european version of OBD2) only works for 2000/2001 Gasoline or 2003/2004 Diesel engines, besides that it will only access engine control and not much more on your car.
Posted: Mon Sep 17, 2007 11:50 am
by rikrose
Yes, UK model. Facelift, but with analogue clock.
Posted: Tue Sep 18, 2007 4:56 am
by Sebastian
Please be a little more precise, can't give you a straight forward answer otherwise.
Model year? Engine (code)?
Posted: Tue Sep 18, 2007 9:53 am
by rikrose
1999 (or 1999.5). It's the 2.7TT engine, either AGB or APB - I'm not sure which, nor how to tell). From your answer above, it seems like it won't work.
Posted: Tue Sep 18, 2007 10:30 pm
by Sebastian
Then EOBD will most likely NOT work on your car, since it was simply manufactured before that standard came into effect. FWIW, a specific diagnostic tool like VAG-COM will work fine and give you actually more functionality than OBD2/EOBD.
Posted: Wed Sep 19, 2007 1:00 am
by rikrose
I was wanting to play with Carman, and before I did, I thought I should figure out whether I can actually read any of the data....
Posted: Thu Sep 20, 2007 6:35 pm
by tdiquattro
I have a bluetooth OBD2 plug in unit from the far east, works well, and I
have tried several programs on an ipaq (PPC with bluetooth obviously) only one works so far ObdGuage v1.3 (freeware)
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... mot_widget
Now I have real time display or MAF, intake air temp, ign timing, rpm, throttle, etc
The ipaq is my sat nav so sits in a cradle anyway so its great, no wires.
The bluetooth obd2 unit should work with other software on a laptop etc, not tried it, I have vagcom and a lead so dont need it for that.
I really wanted boost egts, etc, but I havent found a ppc app that gives me this, maybe I can modify obdguage as it simply calls different engine codes - it obviously isnt designed for 2 of everything as well (V6) and 6 cyl not 4.
Anyway it is very good to be able to see what is going on and it logs as well and gives a peak hold of readings on screen.
Pleased with it, just need to try other software, it is ELM327 based so most of the software should talk to it.
Nigel.
Posted: Thu Sep 20, 2007 6:59 pm
by rikrose
If you were somewhere nearby, I'd suggest trying it with CarMan and my N800...
I think I'm going with a fis-box, instead. Thanks though.
