Airbag Controller 15
Posted: Fri Aug 24, 2007 9:53 pm
by dhali
message as follows: Excessive comms error.. By the way the Airbag light is on in the dashboard.
Any ideas ????
RE: Airbag Controller 15
Posted: Sat Aug 25, 2007 8:13 am
by GrahamS4
What car?
Not sure if it is that exact code that gets thrown, but on the B5 it is common for the connection under the seat to cause the airbag light. Remove, clean, refit an clear the code and see if it stays away. Or just rest and see if it stays awa like mine has.
Posted: Sat Aug 25, 2007 11:41 am
by dhali
Sorry!! B5 RS4 2000. Any particular connector under the seat ? Had a brief look there seems to be loads
btw Am using vagcom 704.1 if that helps.
thanks.
Posted: Mon Sep 17, 2007 12:56 am
by Sebastian
What interface are you using? Anything special we should know about the car (e.g. mods) or the computer you are using (e.g. a MAC running an emulated Windows)?
Posted: Mon Sep 17, 2007 11:02 am
by dhali
A KEY series interface, on IBM T43 laptop with windows XP. My car has the MTM stage 3 if that makes any difference?
Posted: Tue Sep 18, 2007 5:00 am
by Sebastian
Have you checked all relating points in the FAQ yet?
http://ross-tech.com/vag-com/faq_2.html#2.5
Posted: Tue Sep 18, 2007 5:04 am
by Uwe@Ross-Tech
Is communications stable with the other systems in your car (Engine, ABS, Instruments, etc?). I.e. is the airbag module the only one that gives you problems, or are you having issues with all the systems in the car?
Here's a bunch of things to look at:
http://www.ross-tech.com/vag-com/faq_2.html#2.5
-Uwe-
Posted: Tue Sep 18, 2007 8:18 pm
by dhali
can connect with every other module except this one
