Checking car milage
Posted: Tue Jul 24, 2007 10:31 am
by I-want-an-RS
Is there any way of checking a cars milage using vag com to see if the car has been clocked?
RE: Checking car milage
Posted: Tue Jul 24, 2007 10:35 am
by CliveH
Yes, there is a function within the latest version of Vagcom, but it doesn't work with all ECUs.
Re: RE: Checking car milage
Posted: Tue Jul 24, 2007 12:49 pm
by dazzer
CliveH wrote:Yes, there is a function within the latest version of Vagcom, but it doesn't work with all ECUs.
Care to elaborate Clive or has this topic been covered elsewhere?
RE: Re: RE: Checking car milage
Posted: Tue Jul 24, 2007 1:28 pm
by CliveH
Dazzer - you need the latest version 7.
It's in Applications, here : http://www.ross-tech.com/vag-com/tour/a ... creen.html
If the ECU supports it, it will also be reported at the end of a full scan.
Oddly enough, Vagcom won't read the mileage on my 2000 S4, but it did read it on a 1998 S4 I went to look at recently :shock:
The Vagcom online manual suggests that it currently only works with TDi ECUs.
Posted: Tue Jul 24, 2007 3:29 pm
by TDiAvant
What happen's if the ECU has been flashed?
Posted: Tue Jul 24, 2007 6:22 pm
by dazzer
Thanks Clive :thumbs:
Posted: Thu Jul 26, 2007 12:23 am
by I-want-an-RS
Thanks for the info guys, I did notice that at the end of a scan that it had the milage but thought that it had always done it and that I just hadn't noticed it before.
Posted: Thu Jul 26, 2007 12:29 am
by I-want-an-RS
BTW my car is petrol
Posted: Thu Jul 26, 2007 2:50 pm
by GrahamS4
Feature won't work on my '98 S4 (odd as Clive has had it work on a '98 car) but worked a treat on our Golf.
Posted: Thu Jul 26, 2007 10:19 pm
by lengster1
Didnt work on my rs4 but just did today on a 99 a4 turbo i just bought,3 miles different to what the clocks read!!!
Posted: Thu Jul 26, 2007 10:37 pm
by shineydave
there's 2 seperate functions, one that reads the odometer mileage and then a second that reads a mileage calculation held in the ECU which is based on your speed apparantly. i'd guess the one on the vag-com scan is the odometer reading
Posted: Fri Jul 27, 2007 10:08 am
by Dom81
Vag-com mileage scan works on my B7 RS4, and matches the odometer...
Posted: Fri Jul 27, 2007 4:50 pm
by Sebastian
Dom81 wrote:Vag-com mileage scan works on my B7 RS4, and matches the odometer...
Are you sure that you are talking about the same function as others here do? They do NOT mean the mileage displayed in the Auto-Scan, they mean the separate function on the applications screen.
http://www.ross-tech.com/vag-com/tour/a ... ml#mileage
This function is at the moment only supposed to read the mileage from EDC15 Diesel ECU's. However, your RS4 ECU might store the mileage directly in MVB 085.1
Posted: Fri Jul 27, 2007 4:55 pm
by Dom81
Sorry Sebastian - I was referring to the Auto-Scan mileage
