Just got my Ross Tech cable
Posted: Mon Feb 26, 2007 11:50 am
by TopBear
Received my (genuine) cable from the Ross Tech site, and downloaded the latest v6 software and got it all up and working in 10 mins, connecting first time to the car
Ran the autoscan funtion to pull all the 'known' stats from the car, and saved them off, and then cleared them down to get any consistent problems dealt with first.
The misfire on Cylinder 3 & 4 is still there so will prolly order up a couple of coil leads to see if that cures it.
Re: Just got my Ross Tech cable
Posted: Tue Feb 27, 2007 3:38 am
by Sebastian
TopBear wrote:The misfire on Cylinder 3 & 4 is still there so will prolly order up a couple of coil leads to see if that cures it.
Before spending real money, you may want to check the fuel trim values.
http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
Posted: Tue Feb 27, 2007 9:51 am
by MarkB
Posted: Tue Mar 06, 2007 10:42 am
by TopBear
OK so I ran the AutoScan function again on Sunday and got the following 'abbreviated' results back
VAG-COM Version: Release 607.3-UD
Sunday,04,March,2007,20:54:01
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 63351
WUAZZZ8DZ00000000 AUZ7Z0A1852577
4 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
16689 - Cylinder 5: Misfire Detected
P0305 - 35-00 - -
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 56: Radio
Part No: 8D0 035 195
Component: Radio D00
Coding: 00012
Shop #: WSC 63351
2 Faults Found:
00850 - Control Output Active; Radio Amplifier
29-10 - Short to Ground - Intermittent
65535 - Internal Control Module Memory Error
00-00 - -
End --------------------------------------------------------------------------------------------------
Problem is I cant find any reference to the engine\cyclinder layout so I can swap 4 & 5's coilpacks (one at a time) with a 'good' cyclinder) to see if the CP was perhaps faulty.
So from the position of standing at the front bumper looking back to the bulkhead what is the order on each side and is Bank 1 on the left or the right?
Also, anyone got any view as to what the errors in the radio section could be? I'm thinking it may be a bad connection or defective door speakers, as it doesnt sound 100% right when you shift the balance & fader to that corner?
Posted: Tue Mar 06, 2007 3:57 pm
by Uwe@Ross-Tech
Front the stated position, cylinder bank 1 should be on the left, with cylinder 1 closest to the front of the car, and 2 and 3 behind that. Cylinder bank 2 should be on the right, having 4, 5, and 6 in the same order.
-Uwe-
Posted: Tue Mar 06, 2007 4:14 pm
by TopBear
Uwe@Ross-Tech wrote:Front the stated position, cylinder bank 1 should be on the left, with cylinder 1 closest to the front of the car, and 2 and 3 behind that. Cylinder bank 2 should be on the right, having 4, 5, and 6 in the same order.
-Uwe-
Like this then?
Posted: Tue Mar 06, 2007 9:24 pm
by shineydave
exactly like that
