B6 S4 MaF readings...
Posted: Wed Feb 07, 2007 6:22 pm
by tartan_rob
I did some runs the other day, max reading 268G/s @ 6800rpm....
Anyone else done any to compare?
I have no engine mods apart from full Miltek with no cats, std air filter (for some daft reason...)..run was done in 2nd and 3rd gears
RE: B6 S4 MaF readings...
Posted: Wed Feb 07, 2007 9:18 pm
by Uwe@Ross-Tech
268 g/s divided by 0.8 = 335 hp. Sounds just about right for an S4.
What would have been interesting is if you had done runs before and after the exhaust mods. My guess is it doesn't do much except make noise..
-Uwe-
Posted: Thu Feb 08, 2007 5:08 pm
by tartan_rob
Uwe - if that calculation is right then I would definately agree. The noise though is simply glorious....
On another note I thought the 0.8 calculation was only for the 2.7t engine?
Posted: Thu Feb 08, 2007 6:50 pm
by Uwe@Ross-Tech
Nope, basically it takes a known amount of air and fuel to produce a certain number of horsepower. Any variation would be due to differences in the thermal efficiency of the engines, but modern engines should all be very close in that regard. So the 0.8 g/s per horsepower is a valid rule of thumb for all modern gasoline (petrol) engines.
Of course diesels are a completely different animal.
-Uwe-
Re: RE: B6 S4 MaF readings...
Posted: Sun Feb 11, 2007 6:51 pm
by si_hill
Interesting this calculation makes my car 415bhp (332 / 0.8 )
RE: Re: RE: B6 S4 MaF readings...
Posted: Sun Feb 11, 2007 11:18 pm
by tartan_rob
Depends on what mods you have and of course it is not exact but a ball park figure. a std B5 MAF top out around 332 gal/s, to go higher you need to look at an RS4 MAF. You may be runing higher than that. A Fats run will give you a better idea of what power you are running.
Posted: Thu Mar 08, 2007 11:44 pm
by NotNormal
Mine did make about 286 g/s(i think) (s4 - 4.2 v8 B6) - Corey can confirm as he had the laptop on his lap
but lately with that map i've had issues (*see my other tread) LMAO
Posted: Fri Mar 09, 2007 1:21 pm
by tartan_rob
286 is high for a std V8 B6.
Re: RE: Re: RE: B6 S4 MaF readings...
Posted: Fri Mar 09, 2007 4:03 pm
by NotNormal
Tartan_Rob wrote:286 is high for a std V8 B6.
It has the eo sotware on it but thats about it - might be wrong , i'll check with corey and post accordingly .
RE: Re: RE: Re: RE: B6 S4 MaF readings...
Posted: Fri Mar 09, 2007 6:28 pm
by NotNormal
I was wrong, it was 283.1
And i Ment to type Revo software not the eo software
Posted: Tue Mar 13, 2007 11:44 am
by tartan_rob
283.1, Is that with Revo?
Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Posted: Tue Mar 13, 2007 5:18 pm
by NotNormal
Tartan_Rob wrote:283.1, Is that with Revo?
Correct, that's with the Revo software running
RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Posted: Mon Apr 09, 2007 11:37 pm
by william64
Not Normal
Are you a member of Coreys family?
Joking apart.
Did some the other day stock apart from a Milltek and light 19" wheels 272 on the maf, original maf not changed from new.
Re: RE: Re: RE: Re: RE: Re: RE: B6 S4 MaF readings...
Posted: Tue Apr 10, 2007 2:23 pm
by NotNormal
william64 wrote:Not Normal
No, no relation to Corey
Don't gt the joke here ???
What off set are your wheels and are you runnning spacers ??
Posted: Thu Apr 12, 2007 10:44 am
by Corey
Care to explain that comment further please.
