VAG-COM and non VW Audi cars
Posted: Sun Jan 21, 2007 10:14 am
by shineydave
just showing my ignorance here but i was wondering if VAG-COM could be used with alternative software to scan Non VW-Audi group cars since all cars have OBD11 compatible engine diagnostics.
RE: VAG-COM and non VW Audi cars
Posted: Sun Jan 21, 2007 10:33 am
by MarkB
Theres a generic OBD11 part to VAG-COM. Never used it though
Posted: Sun Jan 21, 2007 11:33 am
by shineydave
so from that one would assume it was possible then? has anyone tried it with other makes?
Posted: Sun Jan 21, 2007 3:14 pm
by Uwe@Ross-Tech
VAG-COM *is* software. Whatever interface lead you have (whether it's ours or some 3rd party on) is not VAG-COM.
Current versions of VAG-COM support pretty comprehensive generic OBD-II functions on cars that are use a physical layer for OBD-II that's compatible with the lead. Note however that there are 4 different allowable physical layers, and that VW only uses two of them.
For more info, see:
http://www.ross-tech.com/vag-com/tour/obd-2.html
-Uwe-
Posted: Sun Jan 21, 2007 4:10 pm
by Doug_S2
works on new range rovers!
Posted: Sun Jan 21, 2007 4:16 pm
by shineydave
sorry, i wasn't very clear with my original post, i meant could i use the Ross-Tech interface with alternative software (or Vag-Com software) to scan non VW-Audi cars. from the answers above it would seem that you can depending on the type of car
Posted: Mon Jan 22, 2007 3:18 am
by Uwe@Ross-Tech
Yes -- depending on the car. For example you can forget about most US-model Ford and GM products. Those use the two flavors of SAE J1850 as the physical layer for OBD-II.
It might help if you'd tell us what kinds of cars you're looking at.
Remember also that while OBD-II has been mandatory in the US since 1996, it's only been mandatory in Europe since 2001 (Petrol) and 2004 (Diesel).
-Uwe-
Posted: Mon Jan 22, 2007 10:20 am
by shineydave
Thanks for that Uwe. i'm not looking at anything in particular, i was just curious after realising OBD-II was common amongst cars.
