Login ID for B6 S4
Posted: Wed Jan 17, 2007 4:49 pm
by tartan_rob
I need a B6 S4 login ID for the Central Conv controller. Anyone got one?
RE: Login ID for B6 S4
Posted: Wed Jan 17, 2007 8:26 pm
by PetrolDave
Not sure why you need a login ID - I've never been asked for it when changing the settings on the central convenience controller.
What are you trying to change?
Posted: Thu Jan 18, 2007 10:01 am
by tartan_rob
I am trying to re-code it and the code is not accepted. When I say that, it appears as if it is, but when I go back into the module, the code has not changed. Adaptation works fine however.
Rob
Posted: Thu Jan 18, 2007 4:31 pm
by Uwe@Ross-Tech
I all likelihood, you are trying to enter a coding value which is not acceptable the module.
We can probably help you if you post details of your module, the original coding, and explain what you want to change.
-Uwe-
Posted: Fri Jan 19, 2007 2:22 pm
by tartan_rob
Uwe - the new cable arrived yesterday from you. That seems to have done the trick. Thanks.
