Page 1 of 2
VAG-COM 607..
Posted: Fri Jan 12, 2007 12:43 pm
by tartan_rob
Anyone in Wiltshire got this and can run a test on my car to see if they can access Sat Nav? I have the older VAG-Com version and before I go and buy a newer copy, I wanted to check it worked on the functions that I cannot currently access.
Thanks,
Rob
RE: VAG-COM 607..
Posted: Fri Jan 12, 2007 5:05 pm
by jfeb
Rob. Not quite Wiltshire but I work in Theale (J12 of the M4). If you are in that neck of the woods I'd be happy to help.
RE: VAG-COM 607..
Posted: Fri Jan 12, 2007 5:45 pm
by DavidT
You can download the latest version from their website.
Re: RE: VAG-COM 607..
Posted: Fri Jan 12, 2007 10:35 pm
by MarkB
DavidT wrote:You can download the latest version from their website.
and it will work if you have a recent genuine ROSS-TECH lead...
Posted: Fri Jan 12, 2007 10:38 pm
by DavidT
Thanks Mark, I must have missed something then ?
RE: Re: RE: VAG-COM 607..
Posted: Fri Jan 12, 2007 10:45 pm
by MarkB
If Rob is running version 409 I would think he needs a newer ROSS-TECH lead or he's using a generic lead.
Posted: Fri Jan 12, 2007 11:45 pm
by ZeroK66
Yeah you need a Ross-Tech "HEX" lead to run later than v4.
Posted: Fri Jan 12, 2007 11:53 pm
by DavidT
And one should buy a genuine lead, great value for money :)
Posted: Mon Jan 15, 2007 9:44 am
by tartan_rob
Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
Re: RE: Re: RE: VAG-COM 607..
Posted: Mon Jan 15, 2007 6:02 pm
by PetrolDave
Tartan_Rob wrote:Yep, I have the old "dumb" lead. I wanted to check the newer VAG-com version worked the sat-nav and other functions before splashing out...
Rob
607.3 and a HEX-COM+CAN lead lets me access all the controllers (including both engine ECUs [the RS4 has one per bank], RNS-E and phone) on my 2006 RS4.
RE: Re: RE: Re: RE: VAG-COM 607..
Posted: Mon Jan 15, 2007 6:43 pm
by tartan_rob
HEX-COM+CAN is the serial port on the laptop right?
Re: RE: Re: RE: Re: RE: VAG-COM 607..
Posted: Mon Jan 15, 2007 6:50 pm
by DavidT
Tartan_Rob wrote:HEX-COM+CAN is the serial port on the laptop right?
Not sure, I think all the newer ones are USB Rob.
RE: Re: RE: Re: RE: Re: RE: VAG-COM 607..
Posted: Mon Jan 15, 2007 8:13 pm
by MarkB
Your right Rob
Hex-com + can is serial port. check ross-tech site to be sure
Posted: Mon Jan 15, 2007 9:29 pm
by ZeroK66
I have hex-com+CAN brand new lead and mine is USB.
Posted: Mon Jan 15, 2007 10:16 pm
by PetrolDave
You can order HEX-COM+CAN which is for a serial port, or the more expensive HEX-USB+CAN which is for USB.
Or even the cheaper micro-CAN - but this is for CAN ONLY cars like the Golf V, 8P A3, 8J TT, etc.
Or if you don't want any CAN capability the KEY-COM for a serial port, or the more expensive KEY-USB for USB.
http://www.ross-tech.com/Merchant2/merc ... ode=VAGCOM
