Brake pad warning
Posted: Sun Dec 10, 2006 5:49 pm
A puzzle for you all...
I fitted new brake pads yesterday, went for ones without the wear sensors. Thought to myself 'no problem, just recode the dash so is doesn't show an error'
So today I open VAG-COM and go to change the code, thinking I'll take 02 off the first 2 digits of the code... I then find my current code is 00464
So to me that looks like the only digits that match the ROSS_TECH site are the last 6 and 4 for 6 cylinder turbo petrol.
Anyone any ideas?
http://www.ross-tech.com/vag-com/cars/audiB5.html
Recode for warning lamps:
[Select]
[17 - Instruments]
[Recode - 07]
Write down the existing coding for future reference.
Enter 5-digit code from below
[Do It!]
Look at the first two digits in the coding. Add the values for the options together to get the correct coding.
00 - No available equipment
+01 - Brakepad wear sensor warning active
+02 - Seatbelt warning active
+04 - Washer fluid level warning active (may only work with pre-2000 models)
+16 - Navigation System (non-USA models)
Look at the third digit in the coding (Market version):
0 - "Germany" 24 hour clock
1 - "Rest of World" 24 hour clock
2 - "USA" 12 hour clock
3 - "Canada" 12 hour clock
Look at the fourth digit in the coding (Cylinders):
4 - 4-cylinder
6 - 6-cylinder
Look at the fifth digit in the coding (Distance impulse multiplier):
0 - TDI Engine (non-USA models)
2 - Non-turbo Gasoline engine
4 - Turbocharged engine
So, if you want to have Seatbelt warning and washer fluid warning only in a 1999 Canadian A4 2.8, (add 00+02+04 = 06),3,6,2 = 06362.
Anyone any ideas?
[Select]
[17 - Instruments]
[Recode - 07]
[Do It!]
4 - 4-cylinder
6 - 6-cylinder
