Continuing problems
Posted: Wed Nov 15, 2006 4:52 pm
Hi all,
Colleague here at work has an A3 1.8T and teh EPC light has come, VAGCOM gives the following fault codes:
3 Faults Found:
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
The 17705 pressure drop has appeared before and various hoses have been changed, plus the DV changed and the throttle body cleaned.
Does anyone have any clues?
I've recommended that he take it to a specialist (probably MRC being the closest) but he doesn't fancy a day out of the office.
Many thanks!
Paul
3 Faults Found:
P1297 - 35-00 - -
P1176 - 35-00 - -
Many thanks!
Paul
