SOB - DTC's are back
Posted: Sun Nov 12, 2006 5:30 pm
I thought Id have a look at some codes after the display on the smphony radio seems to have gone garbled!
On the Engine front I got these babies:
4 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
17865 - Exhaust gas temperature sensor 2 open/short to B+
P1457 - 35-00 - -
17746 - Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
P1338 - 35-10 - - - Intermittent
17870 - Exhaust Gas Temp Regulation for Bank 2: Implausible Signal
P1462 - 35-10 - - - Intermittent
On the Radio front I got these beauties:
3 Faults Found:
00850 - Control Output Active: Radio Amplifier
29-10 - Short to Ground - Intermittent
00856 - Radio Antenna:
00854 - Output Radio Display Dash Panel Insert
49-10 - No signal - Intermittent
Anyone else pulled these codes or had a problem with the display on the radio unit going scrambled, oddly enough cd's dont seem to be playing from the changer now either - maybe its the start of the electrical meltdown!
4 Faults Found:
P1457 - 35-00 - -
3 Faults Found:
