Only Dealer can reset this fault?
Posted: Thu Oct 26, 2006 2:33 pm
by viperbl
Mate has just bought an S3 (8L)
The ESP light is on the and garage he bought it from says this happened after the battery went flat and the AA gave it a jump.
I plug VAGCOM into it and under the ABS section it had the following fault
Lateral Acceleration Sensor (G200)
Electrical Circuit Failure
Now, I cleared the code (in VAGCOM), but it instantly came back.
The garage over here says that only Audi Dealerships can clear this fault??!?!?
RE: Only Dealer can reset this fault?
Posted: Thu Oct 26, 2006 2:39 pm
by MarkB
No. fix the fault and the fault indicator will stay off
Posted: Thu Oct 26, 2006 7:56 pm
by Uwe@Ross-Tech
Agreed. Although you may have to calibrate the sensor after fixing the fault.
If you're a registered user and you need help getting the sensor calibrated (once it's complaining about a lack of calibration rather than an electrical circuit failure) e-mail us.
-Uwe-
