resetting the service interval?
Posted: Mon Oct 16, 2006 7:08 pm
by K9ng
Tried searching but can't find how to reset the service interval?
TIA
RE: resetting the service interval?
Posted: Mon Oct 16, 2006 8:01 pm
by S2tuner
If you have a vag-com, it's dead easy.
Connect to address 17, instrument cluster. Click on adaptation (10), select channel 02 and change whatever value is in there to 0. click "save" and confirm then that's it.
HTH,
Mihnea
Posted: Mon Oct 16, 2006 8:20 pm
by K9ng
I don't have Vag-com :roll: Is there any other way?
Posted: Mon Oct 16, 2006 8:29 pm
by S2tuner
uhhhhh, there probably is another way but I don't know it.... I'm sure you can find someone with vag-com not too far away from you though...
Posted: Mon Oct 16, 2006 8:31 pm
by K9ng
Ok cheers, think I know someone.
Posted: Tue Oct 17, 2006 9:51 am
by S4TAN
You can do it from the dash board - i think it goes like this: ignition off, press and hold the second button (the one on the right) protruding from your gauge display, then turn the ignition key to the penultimate position (i.e. everything on but the engine) then the service indicator message will display in the DIS, wait till this disappears then release button, then turn key all the way off. When you next start the car the service indicator should be totally re-set.....
Posted: Tue Oct 17, 2006 9:52 am
by oliew
k9ng,
-Turn off the ignition
-Press and hold the button on the left side of the display while turning the ignition on
-Service OIL will be displayed
-Pull out the button on the right side of the display until the service prompt is gone
-The display should read ---
Ol
Posted: Tue Oct 17, 2006 9:59 am
by S4TAN
.........ok - i knew it was something like that (writing it from memory) :wink:
Posted: Tue Oct 17, 2006 10:12 am
by oliew
:P
maybe both ways work?? :) hehe
Posted: Tue Oct 17, 2006 10:16 am
by S4TAN
Possibly Ol! 8) It's in the manual anyway, surprisingly enough it's under "resetting the service interval" in the index! Who'd've thought it eh? :twisted:
Posted: Tue Oct 17, 2006 3:58 pm
by K9ng
Thanks Chaps I managed to find it in the manual this morning :oops:
Posted: Wed Oct 18, 2006 5:51 pm
by h8cak
Right, Just had to reset my 98 S4. It goes like this...... Ignition off , Press Right button, Turn ignition on, Pull out the left botton, this will reset the OIL service, To reset the inspection you need to press the right one again untill INSP apears, Then pull the left button again, Turn ignition off, Turn on again and hey presto DONE
Posted: Wed Oct 18, 2006 8:53 pm
by Golfather
Yo k9ng, if you ever need VAGCOM, give me a shout :)
Posted: Thu Oct 19, 2006 8:06 am
by K9ng
Cheers Golfather :thumbs: Will have to meet up soon :bigwave:
