alarm ? Vag errors on b6 a4
oliew
Post by oliew » Mon Aug 14, 2006 3:05 pm
Hi there a friend has just bought a B6 X reg audi A4
The alarm keeps going off, she can turn the interior sensors off + tilt sensor off and it doesnt go off...
i ve just vagged it for her and the following faults came up.
3 Faults Found:
00962 - Alarm via. Tilt Sensor
35-00 - -
01702 - Footwell Lighting: Left (w9)
20-00 Short to Ground
01331 - Door Control Module: Driver Side (J386)
80-00 - Single-Wire Operation
Not sure if the Tilt sensor is the one setting it off i cleared the codes and instantly the Door Control Module came back
Anyone have a clue?
thanks
Oli
S4 B5 - MRC
oliew
RE: alarm ? Vag errors on b6 a4
Post by oliew » Tue Aug 15, 2006 4:49 pm
Hi, update, found out now that its tilt sensor is the one setting it off, so why when its parked on level ground??
S4 B5 - MRC
PetrolDave
Post by PetrolDave » Wed Aug 16, 2006 12:29 pm
Sounds like the tilt sensor is faulty.
oliew
Post by oliew » Wed Aug 16, 2006 7:59 pm
Yup. any ideas where these are located ? how much.. and if i can disable it with vag?
S4 B5 - MRC
PetrolDave
Post by PetrolDave » Fri Aug 18, 2006 9:45 am
I haven't found any way of disabling it using VAG-COM. Just have to remember to flick the tilt sensor off switch in the drivers door pocket.
As far As I can tell the tilt sensor is an integral part of the comfort system control module (J393).
Return to “DTC / VCDS”
