same old errors driving me mad (Help)
Posted: Sun Jun 11, 2006 2:12 pm
changed:
maf, dv's, lambda on bank 2 , n75, 126 valve, coolant temp sensor , thermostat, map sensor. No boost leaks at all system holds perfect pressure.
block 32 shows readings -4, -7 -4, -7 Approximate.
What on earth is going on . The car is driving me mad and I just cant figure this out it been going on for a long time and my warranty soon runs out.
Please Help.
6 Faults Found
17965 — Charge Pressure Control: Positive Deviation
P1557 — 35—10 — — — Intermittent
17545 — Fuel Trim: Bank 1 (Add) : System too Rich
P1137 — 35—10 — — — Intermittent
16622 — Manifold Pressure / Boost Sensor (G31) Signal too High
P0238 — 35—10 — — — Intermittent
16486 — Mass Air Flow Sensor (G70) Signal too Low
P0102 — 35—10 — — — Intermittent
16514 — Oxygen (Lambda) Sensor B1 S1; malfunction in Circuit P0130 — 35—10 — — — Intermittent
16534 — Oxygen (Lambda) Sensor B2 S1; malfunction in Circuit P0150 — 35—10 — — — Intermittent
Readiness~ 000 000
Please Help.
6 Faults Found
Readiness~ 000 000
