code help
ronaldmacdonald
code help
Post by ronaldmacdonald » Sun Apr 30, 2006 6:49 pm
After getting royally whipped by an M3 I decided to vag-com the mota (1999 pre facelift S4) and got the codes lifted below, my bentley manual won't boot up :evil: so can anyone intpret the following? cheers :wink:
Control Module Part Number: 8D0 907 551 C
Component and/or Version: 2.7l V6/5VT 0002
Software Coding: 05611
Work Shop Code: WSC 06325
6 Faults Found:
17963 - Charge Pressure: Maximum Limit Exceeded
- - - Intermittent
17746 - Shareware Version. To Decode all DTCs
P1338 - 35-10 - Please Register/Activate - Intermittent
17538 - Shareware Version. To Decode all DTCs
P1130 - 35-00 - Please Register/Activate
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17536 - Shareware Version. To Decode all DTCs
P1128 - 35-00 - Please Register/Activate
maxxximus
RE: code help
Post by maxxximus » Sun Apr 30, 2006 9:27 pm
ronaldmacdonald
Re: RE: code help
Post by ronaldmacdonald » Mon May 01, 2006 12:09 pm
Thanks maxximus :thumbs: , I've emailed Bentley, I reckon some Windoze update knocked out the reader software :(
ronaldmacdonald
Re: RE: code help
Post by ronaldmacdonald » Mon May 01, 2006 6:58 pm
Woohoo, Bentley support it tops, they got my manual working again!
Dippy
RE: Re: RE: code help
Post by Dippy » Wed May 03, 2006 1:21 pm
Check your MAF
Get a pressure test done.
Drive your car on low boost until you have this sorted. Excess boost plus lean mix is a turbo killer.
2001 Silver S4 Avant
Return to “DTC / VCDS”
