Page 1 of 2
Doors autolock-should they after stopping then moving again?
Posted: Thu Apr 20, 2006 12:37 pm
by david7m
Hi
An ADT set my S3 to lock when it gets to about 15mph, which is does. If I stop to let a passenger out without turning the engine off, they can either pull the door handle twice or I press the button on my door to open everything.
When I pull away (remember engine hasn't stopped!) they do not lock again :( Should they?
My girlfriends 2000 Golf does .....
I thought mine would be the same, if not better :wink:
RE: Doors autolock-should they after stopping then moving ag
Posted: Thu Apr 20, 2006 2:05 pm
by MarkB
My S4 doesn't...
Posted: Thu Apr 20, 2006 9:32 pm
by shineydave
mine doesn't either, seems a bit silly really. i'd expect it to re-lock all the doors, maybe there's a Vag-Com setting that changes the function
Posted: Fri Apr 21, 2006 4:22 pm
by david7m
Just seemed strange that a VW does and Audi doesn't.
Posted: Fri Apr 21, 2006 7:46 pm
by davidhodgkinson
mine doesn't either
Posted: Fri Apr 21, 2006 8:48 pm
by CliveH
nor mine - at least we're all consistently surprised :shock:
Posted: Mon Apr 24, 2006 9:33 am
by david7m
clive.harper wrote:nor mine - at least we're all consistently surprised :shock:
:D
Posted: Mon Apr 24, 2006 9:55 am
by DuncS3
nor mine!
Posted: Mon Apr 24, 2006 10:01 am
by CliveH
OK, so it's pretty conclusive that Audis across the range don't do this, but it's suggested that VWs do - so does anyone know if the basecode can be modified to achieve this? Or are the published tweaks the only possibilities?
Posted: Wed Apr 26, 2006 9:17 am
by david7m
I have no idea ...infact, dont even have VAG COM :-(
Posted: Mon May 01, 2006 8:25 pm
by peterb
Well, just to counter this 'all audis ...' statement, I tested my RS6 today - whilst stopped at a roundabout, I opened the driver's door by double pull on the internal handle. Then as I set off, it locked itself again.
Posted: Tue May 02, 2006 10:03 am
by david7m
Doh !!!!!!!!!
Posted: Tue May 02, 2006 10:05 am
by CliveH
There must be a coding fix then...anyone...?
Posted: Tue May 02, 2006 10:17 am
by DavidT
clive.harper wrote:There must be a coding fix then...anyone...?
Sounds like a question for the Yahoo vag-com list. Are ya volunteering Clive ? ;)
Posted: Tue May 02, 2006 10:19 am
by CliveH
Yes, I'll give it a go - if you give me a clue as to what the Yahoo vagcom list is...
