Throttle reset
Posted: Wed Apr 05, 2006 10:11 am
by ZeroK66
Is there anyway to reset the throttle on the S4 so it can learn my driving style?
RE: Throttle reset
Posted: Wed Apr 05, 2006 10:35 am
by KayGee
Key in the ignition turn on but don't start, wait 10 to 15 secs, you'll here the TB re-align itself (easier with bonnet up).
RE: Throttle reset
Posted: Wed Apr 05, 2006 12:01 pm
by ZeroK66
Nice... thought that was what it was.
Anyone do/done this?
RE: Throttle reset
Posted: Wed Apr 05, 2006 12:16 pm
by SimonS4MTM
Only with VAG-COM.
I thought you had to leave it longer than 10 to 15 secs
RE: Throttle reset
Posted: Wed Apr 05, 2006 1:58 pm
by Dippy
I'm sure its 30 secs at least.
It does not "learn your driving style" - all it does is motor the throttle and re-read the sensors so that it can properly control the throttle position.
RE: Throttle reset
Posted: Wed Apr 05, 2006 2:03 pm
by s4woody
vag-com can reset your basic setting..
RE: Throttle reset
Posted: Wed Apr 05, 2006 3:55 pm
by saf
What does Realigning the throttle do exactly.
Whats the advantage or point of doing this?
RE: Throttle reset
Posted: Wed Apr 05, 2006 5:32 pm
by KayGee
10-15 secs is how long it takes to start only takes 5-10 secs to complete. Resets throttle alignment and sets ECU settings back to defaults.
Posted: Wed Apr 05, 2006 8:19 pm
by Morpheous
Not sure if Vag com allows it, but if you go into engine 01 adaption channel 0 it will ask if you want to delete (ECU)learnt values, select forward arrow on VAG 5052 0r 5051 all done.
You will need to set basic setting for throttle afterwards channel 60 on later cars.
Posted: Thu Apr 06, 2006 3:42 am
by KayGee
On VAGCom it is a push button labelled TBA or Throttle Body Adaption.
Posted: Thu Apr 06, 2006 8:30 am
by confusionhunter
Posted: Thu Apr 06, 2006 8:32 am
by confusionhunter
Other than physical removal of the TB, are there any reason why you should need to do this?
Just incase? Or is it common for getting out of sync?
Posted: Fri Apr 07, 2006 9:57 am
by ZeroK66
Thanks confusion... I can use that link now to learn how to use my VAG-Com
