Page 1 of 2
Vag Com Fault Codes
Posted: Tue Feb 07, 2006 9:49 am
by wrightbr
Guys,
I ran vag com on my car the other day and done a search for fault codes and the following fault codes appeared
vag com alerts
DTC REsults
Address 01: Engine
17865 - Exhaust Gas Temp Sender 2 (G236): Open or short to Plus
P1457 - 35-00 - -
Address 55:Xenon Range
01538 - Motors for Headlight Reange Adjustment (V48) / V49
29-00 - Short to
I have searched the site but have not found the answers to the following questions. I am going to relace the gas temp sensor but does anybody know which side this refers to (near side or offside bank?)?
With the Xenon error code if the headlights are set up in the right position then I am assuming that this is not an issue? Is that correct?
Thanks,
Brad
RE: Vag Com Fault Codes
Posted: Tue Feb 07, 2006 11:12 am
by KayGee
According to SS198, G236 is passenger side, assuming yours is a RHD version.
Re: Xenons they should be fine, other drivers will soon let you know if there is a problem with them. Mos garages have a quick check chart on the wall you can drive up to to verify.
Posted: Tue Feb 07, 2006 2:24 pm
by wrightbr
Key Gee,
Many thanks for the reply.
Yes it is a right hand drive model (UK car)so I guess this is the passenger side sensor. Has anybody replaced one of these before? Is it easy to access and is it likely to be hard to remove?
Brad
Posted: Tue Feb 07, 2006 2:37 pm
by s4woody
ive done both of mine..the drivers side when the V (inlet manifold) was off and the other side when it was back on..the passenger side is the worst to do but it is dooable..where abouts are u located??anywhere near south london..
Posted: Tue Feb 07, 2006 3:19 pm
by wrightbr
Thanks S4woody.
I am based in Maidstone in Kent so not far away.
I will probrably get a mechanic friend of mine to do it just wondered how much work was involved for him and if I could give him any pointers to make it easier?
Waiting on a price from Vagparts at the moment for the sensor.
What are the implications of this faulty sensor?
Thanks,
Brad
Posted: Tue Feb 07, 2006 3:58 pm
by kevinw
Brad
I replaced my front near side Xenon sensor last week. Easy job, just take the wheel off and access is easy - got the part from Vag parts £25 instead of £55 from Audi. My Xenons now work again after being stuck on the minimum setting.
However - is yours the Xenon motor?
Posted: Tue Feb 07, 2006 4:30 pm
by wrightbr
Thanks Kevin.
Assume that it is the sensor as well but hard to find a answer for the code. Assume could be both sensors as DTC states (V48) and V49 which I assume is the code for the sensors ?
I will add these to my list for vagparts ;0)
Brad
Posted: Tue Feb 07, 2006 6:08 pm
by s4woody
theres 2 10mm bolts 2 remove off the sheild then u can get 2 it..its tight but can be done..unplug it undo the sensor then refit new then fit back bolts then done..well it sounds easy but just fiddly..
Posted: Wed Feb 08, 2006 10:37 am
by peterb
V48 and V49 are the range control motors, so the fault is either in one of the motors, or the wiring between J431 (the control unit) and the motor. When you first turn your headlights on you should find that the beams come up from the rest position, taking about a second - does this happen? Is it only one light which does this?
Posted: Wed Feb 08, 2006 1:00 pm
by wrightbr
Peter
Not sure I think that the lights rise slightly ( Iwill confirm tonight), and the offside seems slightly higher than the nearside (about 1/2 inch or so ). Where is the control unit located? If the beams are within the MOT settings is this anything to worry about, and if not within the settings then can they be set manually?
S4 Woody
Thanks for the info on the sensor removal.
Brad
Posted: Wed Feb 08, 2006 1:09 pm
by wrightbr
Also changed side light bulb on offside a month or so ago, is it possible there are any wires located nearby for the light motor that I could have knocked off?
Posted: Wed Feb 08, 2006 1:12 pm
by DavidT
I'm reading this thread with interest as my headlights were pointing at the ground when I collected it the other week. I guess its a connection issue as the car was fine before that.
Sorry to hijack the thread.
Posted: Wed Feb 08, 2006 1:13 pm
by s4woody
thats a possibility cos i did that when i changed my oem sidelight bulbs 4 led,s..i soon sussed it out and refitted the wire..and the led sidelight bulbs look like baby xenon lights..wicked..
Posted: Wed Feb 08, 2006 1:37 pm
by wrightbr
S4Woody.
Interesting
can you remeber whereabouts the offending wire was?
Thanks,
Brad
Posted: Wed Feb 08, 2006 4:20 pm
by kevinw
Davidt
I had the same problem and replaced the near side fron sensor (fault code 776). Lights now work fine.
regards
