VCDS killing my battery
Posted: Sat Feb 02, 2013 9:35 am
by RS04YOB
When I run VCDS it kills my battery, can you use VCDS when the car is running, what is the option on VCDS to test the battery to find out the volts/watts amps remaining :beerchug:
Re: VCDS killing my battery
Posted: Sat Feb 02, 2013 10:52 am
by MikeFish
I always have the car running when using it. If you run a test when the engine is off don't you get loads of errors?
Posted: Sun Feb 03, 2013 1:43 am
by Gizmo68
MikeFish wrote:If you run a test when the engine is off don't you get loads of errors?
The only errors ou will get is what is actually present, turn the DRL’s off if you want then do a scan whilst the ignition is on but not running.
