RS4 b7 fault help
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Iceman50005
RS4 b7 fault help
Post by Iceman50005 » Wed Mar 10, 2021 8:43 pm
Hi all.
New to this forum...
Having some problems lately....
Esp light on, after fiew attempts of switching the car off it goes away untill next morning...
Iceman50005
Re: RS4 b7 fault help
Post by Iceman50005 » Sun Mar 28, 2021 11:42 pm
No one ?
coffey555
Post by coffey555 » Mon Mar 29, 2021 11:01 pm
Try posting in the B7 forum, not everyone reads the sub forums.
I had to replace one of the plastic enclosures that the ECU sits in as it was letting in water.
Best have a look to see if you can see any moisture ingress and/or damaged wiring as the looms can get brittle with age.
Misano Red RS4 B7 Avant
dhali
Post by dhali » Tue Mar 30, 2021 8:21 am
How old is your battery ? Worth checking that and brake light switch.? These two are known to cause the light to come on .
Iceman50005
Post by Iceman50005 » Tue Mar 30, 2021 4:31 pm
I have checked brake light switch and it's good, don't know about the battery, but volts are good and no issues starting
Iceman50005
Post by Iceman50005 » Tue Mar 30, 2021 4:57 pm
I already have posted in B7 forum but no replies, and checked the enclosures, no moisture also checked the ECU connectors etc. Looks fine...
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 22 guests
