European Headlight Settings?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Tile Diver
Post by Tile Diver » Thu Jan 10, 2013 4:08 pm
Hi Folks,
Can anyone tell me if the headlights on a B7 RS4 can be re-directed for driving abroad through Vagcom. I'm now living in France and should really get this if it's an easy fix.
Cheers!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
rich_5259
Re: European Headlight Settings?
Post by rich_5259 » Thu Jan 10, 2013 5:33 pm
Have you got MMI? If so look under CAR as that's where I found the Headlight adjustment for driving on the wrong side of the road setting on my B8 S5
S5 Coupe, V8 on 20's with ContiSport rubber
barryrs
Post by barryrs » Thu Jan 10, 2013 5:37 pm
Failing the above there may be a switch on the back of the headlight units to switch beam direction.
Post by MikeFish » Thu Jan 10, 2013 5:39 pm
RS4 doesn't come with MMI.
Do you have adaptive lights? I wonder if their angles can be changed electrinically?
Tile Diver
Post by Tile Diver » Thu Jan 10, 2013 9:00 pm
MikeFish wrote:RS4 doesn't come with MMI.
I think I do have adaptive headlights, is there a sure fire way to tell?
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Post by MikeFish » Thu Jan 10, 2013 9:24 pm
When you start the car with the lights on Auto, have you ever noticed the headlights go up and down to calibrate the height?
The adaptives will go left and right too.
Might be easier if you are parked in front of a wall in an unlit area.
Or just look up the code in your serivce book or in the boot that lists all the options. I'll have a google for the code number for the adaptives.
Post by MikeFish » Thu Jan 10, 2013 9:30 pm
8Q5 maybe?
Post by MikeFish » Thu Jan 10, 2013 9:32 pm
yep its 8Q5:
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending Light (AFS 1)
Post by MikeFish » Thu Jan 10, 2013 9:35 pm
Just doen a quick search and found this for a golf so if you have adaptive it must be possible for the RS4 too:
http://wiki.ross-tech.com/wiki/index.ph ... _with_AFS)
Post by MikeFish » Thu Jan 10, 2013 9:56 pm
Found it.
If you have adaptive lights:
http://wiki.ross-tech.com/wiki/index.ph ... Adaptation
Note; altough the title says A6 it has A4 (8E) in the list (and it's in the actual web address).
If you have Xenon plus:
Note; although tge title says A3 (8P) it is for the A4 too. However, there is a note that says about only a certain model or later versions will work, earlier versions will need mechanical adjustment, but the model it gives is an A3 model :? :?
PetrolDave
Post by PetrolDave » Mon Jan 21, 2013 7:27 pm
MikeFish wrote:Just doen a quick search and found this for a golf so if you have adaptive it must be possible for the RS4 too:
I change my AFS lights into Tourist Mode (and back) while we're on The Shuttle every time we go to France - takes less than 5 minutes using VCDS.
See http://wiki.ross-tech.com/wiki/index.ph ... e_Light%29 just change the setting in adaptation channel 23.
Return to “DTC / VCDS”
