Hi all,
I've just bought a Rosstech cable from a fellow member paulm, ran an auto-scan and came up with the following faults,
Saturday,21,January,2012,13:38:52:10880
VCDS Version: Release 11.11.1 (x64)
Data version: 20111209
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 Q
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2F6700EFED066CC
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-10 - Faulty - Intermittent
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 C HW: 8E0 035 192 C
Component: RNS-E HIGH EU H46 0650
Revision: 03S Serial number: AUZBZ7D0010652
Coding: 0309111
Shop #: WSC 61930 512 00000
VCID: 244DFFC3E4C0DF4
6 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Status: 01111110
Fault Priority: 5
Fault Frequency: 192
Reset counter: 2
Time Indication: 0
Date: 2010.06.18
Time: 10:33:15
Freeze Frame:
Mileage: 655350 km
Count: 1007
Clock: 11:15
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 43
Time Indication: 0
Date: 2011.10.18
Time: 19:04:03
Freeze Frame:
Mileage: 655350 km
Count: 1901
Clock: 20:08
00878 - Connection to Speaker Front Left
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
00879 - Connection to Speaker Front Right
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
02444 - Disk Drive Load / Eject Malfunction
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 2
Reset counter: 42
Time Indication: 0
Date: 2010.09.03
Time: 19:02:05
02005 - Coding Pin
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:19
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF54FF999E50C
No fault code found.
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309111
6 Faults Found:
02261 - Data Medium
014 - Defective
Freeze Frame:
Fault Priority: 5
Reset counter: 2
Time Indication: 0
Date: 2010.06.18
Time: 10:33:15
Freeze Frame:
Mileage: 655350 km
Count: 1007
Clock: 11:15
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 43
Time Indication: 0
Date: 2011.10.18
Time: 19:04:03
Freeze Frame:
Mileage: 655350 km
Count: 1901
Clock: 20:08
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:09
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 42
Time Indication: 0
Date: 2010.09.03
Time: 19:02:05
02005 - Coding Pin
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 1
Time Indication: 0
Date: 2010.06.18
Time: 10:33:19
End ---------------------------------------------------------------------
I have RNS-E but the disk will not read for the nav, I figured this was a lazer lens problem, could someone explain the above results to me please?
The RNSE plays the SD cards fine and the sound is great so I don't understand the speaker faults? could this just be a retro fit that needs coding properly?
Paul
First try of the Vag com
C6 S6 completely standard car just imported with full history from Switzerland - Needs an exhaust!!
B6 S4 Misano Red, KW V3's, RS4 ARB's, Miltek
Re: First try of the Vag com
did you wipe all those and start again,?some faults could have been on there ages
I'll try wiping them,
I'm wondering if somethings given up on the RNSE?
Mate, I retro-fitted the RNS-E and I get some of those faults - it's because the SatNav was not a factory fit. Not sure about the air sensor one though.
'56 ST220 (Sold)
'97 ST24 (Sold - loved lots)
'56 ST220 (Sold)
I got the airsensor one occasionally. I changed it. Don't get the error anymore. Simples. Not that you know when it's working anyway
