B5 RS4 - SatNav & Instruments language change German >
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
rjkflyer
Post by rjkflyer » Fri Jan 21, 2011 12:31 pm
Friend has moved from UK to Switzerland (Tax!!) and purchased a B5 RS4.
Obviously the SatNav and instruments are in German, but he would like English.
Does Module 17 (Inst) > 10 (Adaptation) > Ch04 allow me to recode BOTH Instruments AND SatNav to English in one go by changing from 00001 to 00002?
If not what should I do?
(I have official RossTech cable and VDCS).
Thanks!
Sebastian
RE: B5 RS4 - SatNav & Instruments language change German
Post by Sebastian » Fri Feb 11, 2011 12:58 am
Depends on which nav is actually installed, there were a couple of variants on the B5s available. An Auto-Scan might help to specify.
Sebastian @ Ross-Tech.com
PetrolDave
Post by PetrolDave » Fri Feb 11, 2011 2:28 pm
Changing the setting at address 17 will change the language of the DIS and the DIS-only sat nav, but if he has the sat nav wqith a screen (the RNS-D) then you have to change the langauge of that separately.
There's not much information around on the RNS-D any more, and I can't remember how to do it as it's 7 years since I had one.
rjkflyer
Re: B5 RS4 - SatNav & Instruments language change German >
Post by rjkflyer » Tue Apr 05, 2011 11:34 am
Turns out that it is doable on the actual SatNav: I simply looked through the menus on my B7 and then changed my language to German so I could spot the German equivalent of language change. Then looked on his to spot the same words.
Return to “DTC / VCDS”
