EPC light, opnions or experience required please
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
orkneyrs4
Post by orkneyrs4 » Tue Feb 22, 2011 2:08 pm
Hi guys, the other day I was driving along and my EPC light came on. No funny runnning, as smooth as can be all along the rev range so I continued to work as normal. It stayed on when leaving work but then went out half way home. I plugged in the vcds and it says that there was a momentry loss of air pressure or low pressure to both banks of the engine. This was on low load iirc 22%. So i reset the fault and drove for another 100 trouble free miles.
Today it has come on again on the exact same piece of road no less! Same gentle load as i noted exactly what i was doing at the time. Any ideas guys? I wonder if it may be the power flap or a dirty air filter? I will check tomorrow but though it would be good to ask here as am sure somebody will have had a simillar problem in the past.
Cheers in advance :)
neckarsulm
RE: EPC light, opnions or experience required please
Post by neckarsulm » Sat Feb 26, 2011 10:57 pm
Post this in RS4 forum with fault codes, if it's a V8 it's not uncommon
PetrolDave
Post by PetrolDave » Sun Feb 27, 2011 11:34 am
What fuel you using?
orkneyrs4
Post by orkneyrs4 » Sun Feb 27, 2011 1:40 pm
Can only use 95 Ron as that's all there is in Orkney :(
PetrolDave
Post by PetrolDave » Sun Feb 27, 2011 3:44 pm
Major brand or supermarket-type own brand?
Return to “DTC / VCDS”
