Hi
Does anyone know if the TPMS within the settings menu can be switched on/off via VAG-COM?.. The option isn't in the Settings Menu on the dash display but I can get the pressures etc via VAG-COM so the TPMS must be working..
Ta
C5 RS6 TPMS
C5 RS6 TPMS
RS6 C6 - Stock atm but will be getting an MRC Stage 2 shortly
RS6 C5 - H&R'd and MRC'd Happy Days!..
RE: C5 RS6 TPMS
Hmmm, might be part of the Instrument Cluster coding, but I'm not sure.
RE: C5 RS6 TPMS
In Instruments, there's a value in adaptation channel 61 for the tyre pressure. Maybe it's been turned off? What value have you got in this channel?
Re: RE: C5 RS6 TPMS
Thanks, will check it out and post back..Shoppinit wrote:In Instruments, there's a value in adaptation channel 61 for the tyre pressure. Maybe it's been turned off? What value have you got in this channel?
