Fuel pressure/air leak issue????
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
tartan_rob
Post by tartan_rob » Sat Jan 09, 2010 2:54 pm
I keep getting these warning's on the wifes A4 DTM (2.0tfsi). It has an uprated fuel pump and sports air filter element with a Revo Map. Any ideas?
The fuel consumption is excellent, 40-45mpg on a spirited run. I am thinking the map is too lean therefore on idle the fuel pressure increases..?
Saturday,09,January,2010,13:44:13:06791
VCDS Version: Release 908.1
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 8E0 910 115 N HW: 8E0 907 115 D
Component and/or Version: 2.0l R4/4V TFSI 0070
Software Coding: 01040003180F0120
Work Shop Code: WSC 00654 210 86464
2 Faults Found:
004506 - Fuel Pressure Sensor (G247): Malfunction
P119A - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 94720 km
Time Indication: 0
Freeze Frame:
RPM: 772 /min
Load: 15.3 %
Speed: 2.0 km/h
Temperature: 81.0°C
Temperature: 14.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.970 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - No Signal/Communication - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 94725 km
Time Indication: 0
Freeze Frame:
RPM: 765 /min
Load: 14.1 %
Speed: 12.0 km/h
Temperature: 87.0°C
Temperature: 12.0°C
Voltage: 13.716 V
Readiness: 0000 0000
2017 Kawasaki Z1000
2014 RS6
2014 S1
tartan_rob
RE: Fuel pressure/air leak issue????
Post by tartan_rob » Sun Jan 10, 2010 7:15 pm
I think I found the fault. Two incorrectly fitted pipes were split:
one between the crankcase and the fuel pressure device on the cylinder head
one between the inlet manifold and fuel pressure device as above.....
I would says thanks for the help but......
instead, thanks for looking....
Car has gained power and torque....
2017 Kawasaki Z1000
2014 RS6
2014 S1
Return to “DTC / VCDS”
