01369 - Alarm triggered by Hood Switch
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
KiwiRS4
Post by KiwiRS4 » Wed Sep 16, 2009 4:44 pm
Has anyone come across this before:
Control Module Part Number: 8D0 862 257 E
Component and/or Version: CV-Pump, Alarm, RC D17
Software Coding: 15178
Work Shop Code: WSC 63351
1 Fault Found:
35-00 - -
I've recently replaced the battery thinking it could have been that due to running the battery flat.
Any suggestions on where to look first or how to disable to the hood switch within the ECU via VAG-COM.
RE: 01369 - Alarm triggered by Hood Switch
Post by Shoppinit » Wed Oct 14, 2009 7:54 pm
I've only had this when my battery was left to run flat. Does it come back if you reset it? If so, then probably a new switch will sort you out :)
KiwiRS4
Post by KiwiRS4 » Wed Oct 14, 2009 9:52 pm
Turns out the switch was faulty, simply disconnecting it until you can replace it fixes it. I would say it's down to alot of grime build up as it's right at the front of the car. Luckily the switches are only a fiver...
Return to “DTC / VCDS”
