ODBII CAN MEMOSCAN
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
1781cc
ODBII CAN MEMOSCAN
Post by 1781cc » Fri Sep 18, 2009 1:23 pm
Hi all,
The company that fitted my LPG system uses an ODBII CAN MEMOSCAN system for diagnostic codes, etc... looking at the units on fleabay and they are £70 - sounds good.
Anyone have experience of them that can recommend? or is VAG-COM the only way to go?
S2tuner
Trader (Expired)
RE: ODBII CAN MEMOSCAN
Post by S2tuner » Fri Sep 18, 2009 1:54 pm
VAG Com is the only way to go if you need manufacturer-specific fault codes, codes descriptions, measuring blocks and/or data-logging. OBD2 scanners are good for emissions-related fault codes mainly, and that's about it IMHO.
Hope this helps.
Mihnea
Return to “DTC / VCDS”
