Can you check which tyre pressure sensor is faulty with Vag
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
kwack
Post by kwack » Tue Aug 25, 2009 4:32 pm
Reason I ask is that I get an intermittent sign come up on my RS6 showing that there is a tyre pressure fauly but it doesnt say which tyre.
Stealers want 30m labour to plug in their machine to tell me which one is knackered.
Is there anyone in the Herts area who could do this?
Kwack
PetrolDave
RE: Can you check which tyre pressure sensor is faulty with
Post by PetrolDave » Tue Aug 25, 2009 4:44 pm
You have to look at the measuring blocks immediately after the car has been driven; then you can see the pressure, temperature and battery state results from each wheel sensor.
Return to “DTC / VCDS”
