VAG COM Log discrepancies
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
reevesroadster
Post by reevesroadster » Sat May 09, 2009 10:26 pm
Hi,
I ran VAG-COM autoscan on my B7 RS4 just before it went to the stealers, mid April.
Ive just rerun the autoscan and have a very different log as its failed to scan alot of the addresses and found some additional ones.
Im using the same cable on the same PC and the same version of VAG-COM (805.3) and its a genuine Ross-Tech cable. Only difference is a trip to the stealers (although Im not suggesting its them).
This run tonight has failed to obtain the VIN or the mileage or the engine, ABS, engine II, cent elect., airbags, instruments -etc, etc.
It has also detected a few "new" addresses which werent on the last log.
Ive run the scan twice, with the same results. Any ideas?
Thanks,
Everyone is unique, just like you and me.
PetrolDave
RE: VAG COM Log discrepancies
Post by PetrolDave » Sun May 10, 2009 10:31 am
Which addresses have disappeared, and which have appeared?
reevesroadster
Post by reevesroadster » Mon May 18, 2009 9:16 pm
Just to close this one out - I ran VAGCOM scan again yesterday an all is normal now - all modules checked and all clear.
Return to “DTC / VCDS”
