Misfire Code help - What to do next?
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Rs4Fan
Post by Rs4Fan » Fri Apr 03, 2009 10:02 pm
My car developed a misfire when accellerating above 3,000 rpm.
Codes 16685 and 16688 all point towards multiple possible causes. Are there any other dyagnostics that I can run before simply taking it to the dealer?
VIN: WUAZZZ8DZ1N901954
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 K
Component: 2.7l V6/5VT G 0001
Coding: 10711
Shop #: WSC 06435
WUAZZZ8DZ1N901954 AUZ7Z0Y1536103
3 Faults Found:
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 35-10 - - - Intermittent
Readiness: 0000 0000
Code 16684
Possible Causes
Air Intake System leaking
Fuel Supply faulty
Injector(s) faulty
Ignition Cable(s) and/or Spark Plug(s) faulty
Ignition Coil(s) faulty
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
Camshaft Position Sensor (G40) faulty
Code 16688
Possible Causes
Ignition system
Fuel injectors
Fuel pressure
Running out of fuel
EVAP canister purge valve
Evaporative emission system
Low compression
Base engine problems
Controle Module damaged
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
TopBear
RE: Misfire Code help - What to do next?
Post by TopBear » Fri Apr 03, 2009 10:11 pm
Swap the coil packs around to see if the misfire moves with the coil pack.
Check the plugs are tight enough.
Check for vacuum leaks around the SAI system
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
Rs4Fan
Post by Rs4Fan » Fri Apr 03, 2009 10:33 pm
Wow - that was quick! I'll try that tomorrow. How do I log MAF readings?
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
grizz
Post by grizz » Fri Apr 03, 2009 10:41 pm
When did you last change the spark plugs ??
Unit 20
0151 3366888
Rs4Fan
Re: RE: Misfire Code help - What to do next?
Post by Rs4Fan » Fri Apr 03, 2009 10:42 pm
grizz wrote:When did you last change the spark plugs ??
Will check - will also check whether they are tight.
Really appreciate the help!
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
Rs4Fan
RE: Re: RE: Misfire Code help - What to do next?
Post by Rs4Fan » Sun May 03, 2009 3:15 pm
Turns out I had two bad coil packs. Car runs like a scaled cat again!
'00 S4 (sold)
'01 RS4 (sold)
'93 964RSA
'94 964 Turbo
'08 E63 AMG
'10 Cayenne GTS
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 43 guests
