what else can u do with vagcom apart from check for faults
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
rtd
Post by rtd » Fri Mar 20, 2009 7:12 am
as above really - are there any other uses for vagcom?
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
PetrolDave
RE: what else can u do with vagcom apart from check for faul
Post by PetrolDave » Fri Mar 20, 2009 9:22 am
1) Recode the way many units behave e.g. door locking over 5mph, drivers door only on first press, window closing from remote, etc.
2) Change the coding of units when you retrofit e.g. cruise control, full DIS, sat nav, etc.
3) Reset the service warning indication (fixed and AVS).
You need to look at both the Ross-Tech website (for vehicle procedures) at http://www.ross-tech.com and the Ross-Tech wiki at http://wiki.ross-tech.com. The OpenOBD website is good too at http://de.openobd.org
Blue_Thunder
Post by Blue_Thunder » Fri Mar 20, 2009 10:38 am
Logging to measure various aspects of engine performance, ie: boost spec/actual, MAF readings, misfire detection, long term fuel trims, etc.
Return to “DTC / VCDS”
