ABS and ESP Lights
ABS and ESP Lights
Hi to you all, ime a new member and wonder if anyone can advice, Had a little blast of my RS4 B5 last night came through a roundabout and ESP and ABS lights came on and stayed on,i tried pressing the ESP switch nothing happened, i then pulled over and restarted the car and every thing is ok again, any ideas or should i get it checked out on vagcom, thanks for any advice given,
RE: ABS and ESP Lights
Get it VAG-COM'd.
I had this last year and it turned out to be corroded contacts on the ABS controller and only last week the same happened again and VAG-COM stated the ABS sensor on the offside wheel had failed.
Good luck!
Good luck!
Hi Peakz was it happening regular and have you solved the problem now, thanks
2002 RS4 B5 Misano Red
ABS controller got gradually worse over a period of 6 weeks or so I think.
I haven't got my ABS sensor fixed yet, error has only come up once so far but it'll get replaced imminently.
Users browsing this forum: No registered users and 27 guests
