Fault Codes 17545 Fuel Trim too rich
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
J33RCB
Post by J33RCB » Wed Dec 19, 2007 10:12 pm
Hi All,
I have a A6 4.2 V8 which is throwing fault codes 17545/P1137.
After an evening session on a computer I need some help to interpret the results?
On the O2 sensors on both banks sensor one and two are reading active,
But three and four are both reading dormant? Is that correct?
What is my EVAP is that the same as an EGR?
I need any sort of help to cure these faults and would prefer to stay away from the Main Dealer in Northampton,
Any help gratefully recieved.
Thank you in advance
Jeremy
dssean
RE: Fault Codes 17545 Fuel Trim too rich
Post by dssean » Thu Dec 20, 2007 12:06 am
the fault is at idle,do you have vag com. if so watch the add ( or short term) fuel trim while spraying carb cleaner around the intake system after the air flow meter, pay particular attention to the small vaccum hoses. it would also help to check your afm (or maf) by doing a log run,(you should find the info on here). its more than likley one of these but to go in furtther will need an osciliscope and some proper training.
shame you not nearer to me as we can do this for you a a very reasonable rate.( he says plugging his buisness!!!!) the two lambda sensors after the cat are only a reference point to check the condition of your cat.
regards
sean
shineydave
Post by shineydave » Thu Dec 20, 2007 1:49 am
i had some high fuel trims a while back when Gordon Vag-Commed my S4, turned out it was down to using just any old fuel, switched to V-Max or Tesco 99 and the issue has gone. what fuel are you putting in it? could be it's just not up to the job so the ECU is helping you out by putting in more fuel to compensate
Sebastian
Post by Sebastian » Thu Dec 20, 2007 2:31 am
Sebastian @ Ross-Tech.com
J33RCB
Post by J33RCB » Thu Dec 20, 2007 11:05 am
Thanks so far guys,
I have the Ross wiki pages from PHeads,
I will try the carb cleaner test but I am a complete techno muppet so I will travel anywhere to get this sorted.
Sebastian
Post by Sebastian » Fri Dec 21, 2007 8:52 am
Did you read the related fuel trim page too and checked the measuring blocks for the values in question?
http://wiki.ross-tech.com/index.php/Fuel_Trim_Info
J33RCB
Post by J33RCB » Fri Dec 21, 2007 2:33 pm
Hi Seb,
I have printed out the pages in question, but I need someone to do the work on the car in the Northants area I have a guy with the software but do not know yet weather he can do the work to rid me of the problem.
Buy the way your site is fantastic,
Regards
Jeremy
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 31 guests
