Power cutting out
Power cutting out
My car seems to be misbehaving today. Been running fine recently then today I started it, and gave it slight revs on the accelerator as I was reversing and it almost cut out completely. Only able to drive it by basically increasing the revs very slowly, anything more and it cuts the power like its got a 'choke' out.
Got these codes from VAG-COM
16621 - Manifold Pressure / Boost Sensor (G31): Signal too Low
P0237 - 35-00 - -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
Anyone any idea?
P0237 - 35-00 - -
P0106 - 35-00 - -
Anyone any idea?
Found this link after some Googling, seems to indicate a faulty MAP (not MAF) sensor.
Is this a diy job to replace, or should I get (another) job lot of vaseline in?
G31 is the boost sensor which sits in the top of the tbb. Easy to change although getting the old clip off is a bit of a bugger. Expensive to buy though, think I paid around 100 quid. Buy the proper hose clip too, only about 30p.
F96 is in the ecu and I'm not sure if it can be changed as a seperate item but I'm sure someone on here (probably Doug) will.
I think I have a spare G31 as I replaced mine when it wasn't actually the problem.
I will have a look today for you.
Cheers fella, Your right enough, I was quoted £88 inc VAT from my local Audi dealer, whilst VAG-Parts are charging £48 inc delivery for the same part.yorkie wrote:I think I have a spare G31 as I replaced mine when it wasn't actually the problem.
I did think about posting up, to see if anyone had one spare, but really didnt think there would be, so I've ordered a new G31 from VAG Parts but its gonna take a week to get here, as its a special order part.
- ChipHazzard
- mikeyquattro
- Top Gear
