Novel VAG-COM use - Road Dyno
Diagnostic Trouble Codes (DTC) / VCDS (VAG-COM) forum
Crunchster
Post by Crunchster » Sun May 27, 2007 7:31 pm
Was doing some logging on my brothers MRC Stage 1 tuned B5 RS4 yesterday when found a VAG-COM block (120 IIRC) that records "engine torque (actual)".
Now, I'm a bit dubious as to how this is measured, but I took the logs, calculated torque in lbft (Nm*0.737562), then converted to bhp (torque in lbft*rpm/5252), and plotted it on a graph. Here are the results:
3rd gear
5th gear
Comments welcome, and post your graphs :D
Crunchster
Crunchster
RE: Novel VAG-COM use - Road Dyno
Post by Crunchster » Sun May 27, 2007 7:34 pm
PS This was with 1.5 bar peak, 1.35 held tailing to 1.2 bar at peak power. Charge temps were in the 50-60 degrees C range at the end of each pull (particularly in 5th) so not a bad result I reckon... :)
Crunchster
Post by Crunchster » Sun May 27, 2007 7:50 pm
Here's the boost plots, MRP (bar) vs rpm
shineydave
Post by shineydave » Mon May 28, 2007 12:06 am
looks good to me, maybe Uwe would be good enough to pass comment on how block 120 is created so we know how valid the data is
Dave
Crunchster
Post by Crunchster » Mon May 28, 2007 11:21 pm
I have no idea how it is calculated, but suspect it may be derived from mass air flow. The logging parameter is "engine torque (actual)", then the rest of the calculations to get from Nm are pretty straight forward, as detailed above.
Return to “DTC / VCDS”
Users browsing this forum: No registered users and 69 guests
